need help ls7 parts ???
Old Jan 7, 2008 | 03:03 AM
redline632's Avatar
Default need help ls7 parts ???
HI,
I need part number for ls7 timming set & ls7 engine damper
racing or gm and did this right parts for ls7 thanks
12578449 Engine Cylinder Head
12603281 OIL TANK
12568976 Engine Intake Manifold
12598212 Engine Oil Pump
89017592 Water pumps
89018171 Engine Piston
15210122 HOSE
15210117 HOSE
12582179 Engine Cylinder Head Gasket
89017776 Engine Piston Ring Kit
12579615 Engine Valve Rocker Arm
12579617 Engine Valve Rocker Arm
Old Jan 7, 2008 | 06:42 AM
performance fast's Avatar
Default LS7 part#
The LS7 balancer is #12599862
Balancer Bolt #11570163
Cam sprocket #12586481
Crank gear #12581278
Timming chain damper #12581276
Timming chain #12586482
Cam gear bolts 3 required #12556127
The piston part# you have is for .020 oversized piston the standard size is #12602624.
All of these part# are right out of the 2008 LS section of the GMPP catalog. There is a great part# list in there.
It also shows all the different LS series engine sizes and applications. It's pretty informative.
Old Jan 7, 2008 | 02:43 PM
redline632's Avatar
love you man thanks for your help
By Brett Foote | 2026-06-04 05:00:17
