what block
Old Jan 13, 2008 | 02:19 PM
ls1firehawk's Avatar
Default what block
I want to build a 408 with a dc1 and I do not what block to use 6.0 Iron or a ls2 what do use think
Old Jan 13, 2008 | 04:09 PM
Shawn @ VA Speed's Avatar
depends on what you want,either will do fine,if on a tighter budget-go iron,if you want less weight-go alum
Old Jan 30, 2008 | 05:36 PM
Fast99408's Avatar
the iron block wont flex in high horsepower rang and if you really want a block that cna hold osme power do the LSX block i ahve athe iron its better aluminum when you put to much power to it it will flex on you
