LS2 NASCAR Build
Old Jan 16, 2008 | 09:17 PM
dmc454's Avatar
Default LS2 NASCAR Build
Had a chance to help build one of the NASCAR LS2 motors.Great experiance for when I do my motor.Learned alot about these motors.Not as hard as I thought it would be.The more I learn about engine building the more I figure I need to learn.Enjoy
Attached Thumbnails LS2 NASCAR Build-100_0396.jpg   LS2 NASCAR Build-tdc.jpg   LS2 NASCAR Build-pistons.jpg   LS2 NASCAR Build-front-cam-drive.jpg   LS2 NASCAR Build-ls2-clutch.jpg
Old Jan 16, 2008 | 09:39 PM
Greg Fell's Avatar
Nice! What sort of heads do those use??
Old Jan 16, 2008 | 10:06 PM
dmc454's Avatar
Default Cnc 243
They were a set of CNC 243 heads.Dont know much else about them.Part of the motor kit this belonged to.I had a chance to help dyno one of these a couple months ago.It made 592 HP.The whole motor is from WEGNER Racing Engines and its a piece of art.
Attached Thumbnails LS2 NASCAR Build-100_0405.jpg   LS2 NASCAR Build-100_0436.jpg   LS2 NASCAR Build-100_0437.jpg   LS2 NASCAR Build-243.jpg
Old Jan 16, 2008 | 10:18 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Thanks for sharing these photos and your comments.
Steve
Old Jan 17, 2008 | 06:26 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
What clutch is that? Looks pretty light.
Old Jan 17, 2008 | 07:10 AM
Stang's Bane's Avatar
WOW, 592 hp on a hydraulic roller. I am assuming stock cubish???
Old Jan 17, 2008 | 08:00 AM
ss1's Avatar
ss1
Looks like a Quartermaster Optimum-V 7-1/4" triple disc. Nice stuff!!!
Old Jan 17, 2008 | 08:13 AM
AU N EGL's Avatar
NASCAR LS2 motor???
592 hp on PP243 heads dayum
Very very cool
so what size of cam ?? and other good details??
What teams will use these?
Old Jan 17, 2008 | 08:36 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
We have a couple of customers that race against these engines at Slinger Speedway in WI.
Old Jan 17, 2008 | 10:31 AM
dmc454's Avatar
Default Clutch& cam
Quartermaster clutch kit.And I think its a off the shelf Comp Cam.a 281 roller.It can spin to 8000 rpm on upshifts on restarts but can run all day at 7000 rpm.They told me power is in the head flow and they are not saying anything about that,I tried.
Attached Thumbnails LS2 NASCAR Build-100_0392.jpg   LS2 NASCAR Build-100_0403.jpg   LS2 NASCAR Build-clutch.jpg   LS2 NASCAR Build-throwout-bearing.jpg
Old Jan 20, 2008 | 06:09 PM
SS Enforcer's Avatar
Interesting to note there not running roller tip rockers for this motor. Are they running a controlled rocker or is it a left up to the builder to select what they want ?
cheers
Old Jan 20, 2008 | 09:22 PM
dmc454's Avatar
Default Ls2 Spec Motor
You can only run what they send you in the kit,or you can lease a built motor.Everything has a coded square on every piece.The most you can do is tune on the carb and timing.Its for an even playing field.
Old Jan 22, 2008 | 08:15 AM
LS1TECH Sponsor
I think the conversation of dual vs. single all depends on your valvetrain dynamics. Why, if your valvetrain is 100% in control, no valve bunce, would you even consider dual springs?
I think the reason a lot of shops use the dual valve spring setup is because that is what they have used since they started building engines. It has been proven over and over that if you can keep your valvetrain light, you only need to control it with a beehive valve spring.
And, vs. a standard dual spring setup, a beehive will out live a dual and be less harsh on the rest of the valvetrain components.
Old Jan 25, 2008 | 07:49 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Guys, please keep this thread on topic. Enough of the valvespring arguments. Just take the photos for what they are. I, for one, am happy this gentlemen snapped pics and came here to share them.
Old Jan 25, 2008 | 07:56 AM
kerryt1's Avatar
Cool pictures. What intake / fuel system do they run with these?
Old Jan 26, 2008 | 01:10 AM
01ss#5536's Avatar
Are you attending NASCAR tech?
I graduated from there August 2003.
Old Feb 8, 2008 | 08:22 AM
Quick 99's Avatar
Sweet! Hope everything is going/went well.
(Booo nascar: Yaay F1)
Old Feb 8, 2008 | 11:12 AM
pist0lpete's Avatar
What class in nascar do they use these engines in?
Old Feb 8, 2008 | 03:43 PM
512bbi's Avatar
The heads look CNC cut but no hand porting?
Old Feb 9, 2008 | 11:16 AM
See5's Avatar
Wegner ports the heads. They get the hp at high rpms with a carb intake and a GA like cam which is not terribly streetable.(why should it be) Light single springs (PSI) and valves.
