AFR 225 vs. Ported L92s
Old Feb 20, 2008 | 04:12 PM
Brian Tooley Racing's Avatar
Originally Posted by 2manycars
Not trying to hi-jack the thread but which of these heads do you guys think would make the best torque from 3500-5500. I know a lot of guys just want to use whatever makes max HP even if its at 7500 but for a street engine I don't know if anyone's opinion differs. My 449 is 4.16 bore x 4.125 stroke, what is the BxS on a 455?
The biggest thing that sets the current cathedral port stuff apart from the L92 and LS7 heads is the intake. The L92 makes torque like a Fast, but tends to not make the same top end power. The LS7 makes for big top end power at the sacrifice of mid range torque. I have a customer in CA that had two 427 cars, one with stock LS7 heads and intake and one with undersized TFS 225's and a Fast 90. They both made 520 RWHP with smallish cams, but the TFS/Fast combo was about 60 RWTQ better down at 3000-3500 RPM. This is not so much because of the heads, but because of the intake manifold design. This is why you see guys with TFS 235's and Fast intakes making 600+ RWHP and 550+ RWTQ, with HUGE torque curves.
Check out post #103 below
https://ls1tech.com/forums/showthrea...ght=lmr&page=3
Hope this helps.
Old Feb 24, 2008 | 05:34 PM
2manycars's Avatar
Thanks but I know about the lack of an aftermarket intake for square ports. Thats one of the reasons I'm dragging my feet on picking heads.(That and $) I guess there is really no way to campare apples to apples untill the Weiand or FAST units come out for the L92's. Last I heard the Weiand (which is supposed to be T1TS when it comes to midrange torque) is being pushed to a maybe in summer and the FAST as hopefully around SEMA. So right now I'm thinking PRC L92's w/L76 until the Weiand comes out and then I can be a Guinea Pig for that intake.
