383 project
Old Feb 16, 2008 | 02:23 PM
vette_c6's Avatar
Default 383 project
i want to add Piston + connector
what is the size people are using here ?
and how many over bore are you using ?
all of that with my C6 2006 stock heads
and what is the best piston Comprission For 8 PSI Magna
and what Benefit will i get
so it will be Like c6 with all the stuff in my Signature Put 2.8 Pulley (8psi)
then
installed the Piston and connector only
how many PSI will i get ? how much horse power it will be ....
and please compare it with the stock Piston Weight and connector rod weight
i need to know the numbers
all of this question to know ,, will it be worth changing the piston and connector or no
many thanks
Note : i need answers from people who tried it or people who works in companies ,, cuz i will take the answers here seriously so please no guessing guys
thanks
Old Feb 16, 2008 | 09:06 PM
HEMIETR's Avatar
Where are you located?
Old Feb 17, 2008 | 01:53 AM
vette_c6's Avatar
middle east kuwait
my car cammed 222 228 566 571 lope114
long tube hedrs 1 7/8 magna charger 5 psi with pulley 3.1
520 hp on wheel
Old Feb 19, 2008 | 12:09 PM
Sigforty's Avatar
You will probably end up with a 402 stroker and not a 383. The 383 is based of the Ls1 and Ls6. The C6 corvette came with the Ls2 which is a 4 inch diameter bore.
