Quick question on LS3
Old Feb 21, 2008 | 02:47 PM
landonew's Avatar
Default Quick question on LS3
I noticed that the LS3 shares the same head design as the Ls7 and l92. I suppose this means that my AFRs won't fit huh?
Old Feb 21, 2008 | 02:56 PM
HeapaShifter's Avatar
The LS3 heads and L92 heads are the same. AFR heads will fit on the block, you'll just have to switch to something like a FAST intake.
Old Feb 21, 2008 | 03:00 PM
landonew's Avatar
I already have a FAST 90/90 on the car. Thanks.
Old Feb 21, 2008 | 07:13 PM
drain89's Avatar
unless you've got a block that's 4.00" or larger, you can't use them anyways.
Old Feb 21, 2008 | 11:25 PM
landonew's Avatar
you mean 4" stroke? I am confused. What can't you use?
Old Feb 22, 2008 | 11:40 AM
drain89's Avatar
4" bore. stroke doesn't matter
Old Feb 24, 2008 | 09:13 PM
TA455's Avatar
I think hes asking if he can use his AFR heads and Fast manifold on an LS3 block.
