new high performance water pump
It has been around for awhile. Never tried one!
I run a bigger radiator and a standard size crank pulley. Don't have any cooling problems, yet.
Here is the Edelbrock part number:
Two-Piece Pump for GM Gen III & IV LS (3/4" pilot shaft) 8896
* Fits 1997-2007 GM Gen III LS1 and Gen IV LS2 engines with 2004 & later two-piece Thermostat (GM PN 12581594). Has 3/4" ball/ball bearing. Dimension from block surface to hub: 6" (Replacement Cartridge for Edelbrock GM Gen III & IV LS water pump #8897)
The Evans pump is designed for increased flow but also more equal bank to bank flow than the stock pumps. We had tests run of these pumps (Evans, stock LS1, Meziere electric) during development of the Darton MID sleeves for the LS engines. The stock pump flow to the right bank decreases noticeably past 5,500 rpm.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
edelbrocks pump
