WCCH L92s___Pics...
Old Mar 6, 2008 | 07:35 AM
WKMCD's Avatar
Originally Posted by pwtr02ss
Let's see some flow number's. I'm a little partial to narrowing the guide bosses versus making the ports bigger. So let's see cc size of the runner, verses flow number.
Old Mar 6, 2008 | 09:01 AM
Johny GTO's Avatar
i am still up in the air on whether to go with these heads or not. I am scratching plans to get ported LS6 heads. Now it looks like either trickflows or AFR's. Which do u think be a better bet for a stock cubed LS2
Old Mar 6, 2008 | 09:20 AM
VH5150's Avatar
Dynojet Fan
Originally Posted by WKMCD
Looks don't count. Flow quality does.
I understand that... that's not what I ment..... I was refuring to the pix that were posted...
Old Mar 6, 2008 | 09:48 AM
Richard@WCCH's Avatar
Originally Posted by Mr.Big
Richard do you sell them (L92heads) set up with the Harland Sharp L92 Rollers installed... I've seen where some slight machining has to be done for clearance reasons, and I just want the full package ready to install... PM me details and pricing if you do not want to post info... thanks...
Yes, we have a program to clearance the heads for Harland Sharp's rocker arms. The cost to machine a pair of heads for the clearance runs $40.00 per pair. The rest of our L92 pricing is listed on our website.
Richard
Old Mar 6, 2008 | 09:52 AM
Originally Posted by Beaflag VonRathburg
I know you guys carry All Pros, but do you do CNC work on them or would you send them back to Bob? I have a set of their LS1 bare castings that I'd like to get finished.
PM sent.
Richard
Old Mar 6, 2008 | 10:54 AM
turbo'd stang's Avatar
I've got a set of L92's that another vendor did, it looks like they used a drill bit What do you charge to just CNC a set..assuming they didn't screw them up too badly?
Old Mar 6, 2008 | 11:53 AM
PM sent.
Richard
Old Mar 6, 2008 | 12:40 PM
1997bird's Avatar
Early results say these heads like lots of timing to produce results. I ran 12:1 on my first iteration and could only run 26 degrees of timing. Reduced the SCR to 11:3 and now run 30+ degrees. I picked up considerable HP with the additional timing.
My $.02
Kevin this motor would be on alcohol, so I would have an unfair advantage over you pump gas guy's.
Old Mar 6, 2008 | 12:51 PM
Sharpe's Avatar
Old Mar 6, 2008 | 01:39 PM
edcmat-l1's Avatar
If Richard saw results from widdling the guide bosses down, I'm sure they'd be done that way.
Old Mar 6, 2008 | 05:27 PM
WKMCD's Avatar
Then everything I know is out the window...
Old Mar 7, 2008 | 12:43 AM
  #32
1997bird's Avatar
Yep, about a 3 to 1 burn ratio from alky to gas. So in a 25 lap main on a 7/16 mile track they will go through roughly 15 to 20 gallons of alky($3 per gallon last year). The trade off is the extra octane and the cooling properties that help add 20 to 25% more power on average. At 5300 ft. we need all the power we can get to offset the loss of air density(roughly 20% less HP).
Old Mar 7, 2008 | 05:55 AM
  #33
WKMCD's Avatar
I went to UNM for 2 years while my knees healed up from motocross and ran at a small oval track outside the city sometimes. Tiny little jets in the carbs to make any power. Probably 30% smaller than we would run at sea level.
Old Mar 7, 2008 | 06:27 AM
  #34
pwtr02ss's Avatar
I know everyone has their own theory's and to each their own. You see thousands of other professional head porter's do it, so maybe he's on to something new
Old Mar 7, 2008 | 10:34 AM
  #35
1997bird's Avatar
If that were always the case we would all be driving Mustangs, b/c there are millions out there that everyone seems to have.
Old Mar 7, 2008 | 06:25 PM
  #36
Mr.Big's Avatar
Richard
Thank you Sir...
Old Mar 10, 2008 | 08:06 PM
  #37
edcmat-l1's Avatar
Bump for a great product. Hope ya sell tons of em Richard.
The engine is going together. Should have results end of the month. We're using a super secret, custom grind cam that was speced out by the cam witch doctors. We (the witch doctors) used a crystal ball and a weegee (SP) board.
Seriously though, its a fairly mild cam, even less than what WKMCD is running.
Old Mar 11, 2008 | 10:07 AM
  #38
Thanks a ton for all your feedback Ed. I look forward to following up on how this engine project turns out. Nice choice on the cam too.
Richard
Old Mar 11, 2008 | 09:56 PM
  #39
99blancoSS's Avatar
Great sponsor here to deal with, thankx for all your help Richard, I lucked into a pair of AP's Great looking work on the L92's.
Old Mar 12, 2008 | 09:10 AM
  #40
blu00rdstr's Avatar
Beautiful work!
