ARP Main studs . Torque sequence
Old Mar 20, 2008 | 06:26 PM
BadLtBlu99TA's Avatar
Post ARP Main studs . Torque sequence
now when going about torqueing the mains , i know i got to start in the middle main cap , but do i just start with the highest torqued 2 bolts then do the other 2 after in the center , do the 4 in the middle first or just do the 2 and then move on ? the the one next to it ?
Old Mar 20, 2008 | 08:54 PM
bluethunder364's Avatar
You are aware that once you pull the stock bolt set-up and go to studs and have your torque sequence correct, you have to have the block aligned honed to make sure you are straight across all your mains. With the crank out the mains are torqued to spec. and checked. Studs change the clamping force. They are much better than bolts you just have to set them up correctly. Hope this helps.
Old Mar 22, 2008 | 01:27 AM
racecar's Avatar
I used the factory torque sequence with ARP studs. Unless you really change something, your block should be fine without a hone job. When checking bearing clearances, you must have the side bolts installed and torqued, or the numbers will come out wierd.
Like Thunder364 is implying, everything has to be right on with these aluminum blocks, or your clearances will be off.
When you install your crank, if it does not turn freely, you need to check the block.
