Furrels?
Old Mar 21, 2008 | 04:15 AM
slowjoe99's Avatar
Question Furrels?
I just bought Katech connecting rod bolts. The instructions say to remove the stock bolts and furrels. What are furrels? we didn't see anything to remove besides the bolts...
Thanks guys
Old Mar 21, 2008 | 08:09 AM
Jon@WAR's Avatar
If you look at the mating surface of the rod, you will see a hollow dowel on each side. That is what you remove.
Old Mar 21, 2008 | 08:21 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
The 99 shouldn't have them, it should have the first design bolt which did not utilize the ferrul.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Mar 21, 2008 | 10:09 AM
Azrael's Avatar
The ferrule should come out with the rod bolt, like mentioned above it is the collar/retaining sleeve (3) seen on the right hand rod bolt in the diagram above. Also as stated above your car shouldn't have them...
Old Mar 23, 2008 | 02:07 AM
slowjoe99's Avatar
thanks guys! my car didn't have em
