ok so my compression is? l92 related
Old Mar 24, 2008 | 08:36 PM
89Formulaws6's Avatar
Default ok so my compression is? l92 related
i got my cam sepcs but they are
but i have a 4.030 bore 4in stroker 1.8 valve reliefs, my pistions stick out the bore .012 and i'm going to use the ls7 headgaskets since they are cheaper then cometics but they are .052 compressed from what i've been told.
so that puts me around 10.7:1 correct? now is wanting 11.4:1 at most asking too much for a street car on 94 octane?
because my tuner told me 11.4 is what the heads like and somewhere around 30* of timing will i be able to get that many * with that compression?
so if i need to mill my heads to get 68cc's even to get 11:1 i'd be happy
how much off of the stock 70cc is it to get to 68
Old Mar 25, 2008 | 12:26 AM
95FbFormula's Avatar
milling .030 gets 65cc so something like .010 will net you 68cc you can go to 65cc or farther I am going with 65cc on mine. if 68 will get you 11-1 65cc should be about 11-5
Old Mar 25, 2008 | 05:43 AM
WKMCD's Avatar
Use .006 mill per cc to calculate.
