What injectors should I run?
Old Mar 26, 2008 | 01:35 AM
05JUDGE's Avatar
Default What injectors should I run?
I am about to start installation of my 427 L92 stroker. I have L92 ported heads, big cam, ported intake and tb. I have the L92 injectors, but wasn't sure if they are going to be big enough. Should I step up to 42# or should I go even larger?
Old Mar 26, 2008 | 06:52 AM
See5's Avatar
The 40# L76s should be close, watch your IDC. If they go >90% I suggest the new FAST 50# as they are the same Gen 4 style and they tune in much better than the SVO 42s In my opinion.
Old Mar 26, 2008 | 05:24 PM
2000_SS's Avatar
i put flow-matched 42# Lucas injectors from New Era in my stock-bottom-ended motor. i'll be using them again in the new, bigger motor.
