building an aluminum ls3 block
i used the search but cant find exactly what im looking for.
i currently have a built ls1 in my 99 Z
( specs in sig. )
i didnt do anything to the bottom end at all when i built it. i found an aluminum ls3 block and want to stuff it into my current setup.
i dont know much of anything about the ls3 bottom end honestly. i was wondering if my current heads, cam ,exhaust, motor mounts, ect... will work on this shortblock.
These make for KILLER motors and I recommend contacting a top LS engine builder like Erik Koenig of HK Enterprises or Vengeance Racing or LME, as they can build you or if our building on your own, at least steer you in the right direction and may even be able to sell you some great forged internals for your future LS3/L92 motor!
its not exactly what i was leaning towards though.
im wanting to make sure all my existing pieces will work on this block. the only drawback i can see is the heads i have right now. i may go a different route then the prc stage 2.5 5.3 heads im currently running, its a dd so i dont want an extreme compression ratio. i spend alot of time n money on my current setup last year. i was looking to build a bottom end for the motor when i found a deal on the 6.2 aluminum block.
im not saying im not going to put a stroker kit in there, i might. time will tell. for now i need to know if fall my front accessories are will work, motor mounts, headers, and internals cam pushrods lifters oil pump ect....
honestly the stickys need to be cleaned up imho
also the search function just aint what it used to be
