Replacing Rod Bolts. Tips/Tricks Needed Please
Old Apr 6, 2008 | 02:28 AM
Sweet71's Avatar
Default Replacing Rod Bolts. Tips/Tricks Needed Please
So im gonna start removing my k member tomorrow to change my rod bolts in my 2000z28, just currious if anybody had any tips or tricks on doing this or any kind of advice?
Thanks Alot!!
Old Apr 6, 2008 | 08:15 AM
3timeracin's Avatar
Anytime you replace rod bolts you normally have them resized even with todays cracked cap and dowel technology i have seen the lower rod cap distortion after being untorqued. This could cause your bearing clearance to change when retorqued with the new bolts. This is caused by the heat cycles it has endured while being torque together.
Old Apr 6, 2008 | 11:11 AM
THE RED "BLUR"-408's Avatar
Warning: Bad Trader
why are you changing them in the first place?
Old Apr 9, 2008 | 01:20 PM
LSZ's Avatar
LSZ
Probably because stock rod bolts are junk!
Old Apr 9, 2008 | 07:45 PM
Blindmelon's Avatar
GM rods are good just the bolts suck. I replaced mine with ARP 2000 bolts. Machine shop doing the work along with new Diamond pistons (L92 heads) with L92 valve reliefs in the new Diamonds. I know the rods need to be machined back to spec after changing bolts out like was said. Arp 2000 bolts will make it safe to 500 to 600 rwhp. Also factory crank on a LS2. I will make about 430 rwhp on motor & 600 hp on 2 stage nitrous with the Diamond pistons also better bearings. LOL
Old Apr 9, 2008 | 09:01 PM
KCS's Avatar
KCS
Moderator
Here's a tip, get the crank turned and resize the rods. Don't take the chance, unless you have money and time to burn.
Old Apr 9, 2008 | 10:34 PM
cam's Avatar
cam
Katech rod bolts here. Swapped em in at 72K miles and have tenK on them since. I followed their instructions and lubed em with their special lube and did did one bolt at a time. Limiter is now set at 7K and I bounce off everytime I take the car out. No troubles
