ARP 234-5608 Main Studs - Am I missing something
Old Apr 13, 2008 | 07:26 AM
VesperWillow's Avatar
Default ARP 234-5608 Main Studs - Am I missing something
For those who have used those studs, look at the following pic. I've used ARP studs before for heads, this is the first time I've used them for my caps. It says to hand-tighten the studs in place, as always. Then put the nuts on top, torque to spec.
I hand tighten them, and the windage-tray studs end up sticking up so far the nut can't reach the cap. I ordered them from summit. What came in the sealed box was the windage studs, the cap studs, the side bolts, 20 nuts for the caps, 10 nuts for the studs and moly grease. Were there supposed to be any washers?
Am I supposed to tighten the windage tray studs tighter? The threads have all been cleaned and chased, they're in with about 10lb-ft of torque so far, I mean it's beyond hand tight at this point and they still won't reach. Let me know if I'm just doing something wrong..
Attached Thumbnails ARP 234-5608 Main Studs - Am I missing something-2345608.jpg
Old Apr 13, 2008 | 09:04 AM
97F1R408's Avatar
There should be two different length studs, and the block is drilled and threaded to match. Take a closer look you should just switch them around. Unless your kit is packaged wrong or something.
Old Apr 13, 2008 | 09:41 AM
96 Comp T/A's Avatar
You have the studs reversed. Swap them around.
Old Apr 13, 2008 | 11:25 AM
racer7088's Avatar
Arrow
Yep what he said! Just switch them and you will be fine.
Old Apr 13, 2008 | 11:39 AM
Well I thought of that, but if I swap them around I have to redrill the holes in the windage tray. Is this right? I mean I'm fine with that, it's just annoying.
Old Apr 13, 2008 | 11:47 AM
racer7088's Avatar
The ones with the longer threads are the outside studs so you must change them. With studs you do have to drill out the windage tray holes a little more.
Old Apr 13, 2008 | 11:51 AM
Cool thanks, just wanted reassurance.
Old Apr 14, 2008 | 07:45 AM
Just an update, as the thread shows I had the studs backwards. The studs with the "longer" threads goes on the outside. Then just ream out 3 holes in your windage tray to allow for the larger studs to stick through.
That'll teach me to try and build a rotating assembly in the wee hours of the morning.
Old Apr 14, 2008 | 01:44 PM
rons 00z's Avatar
try adding alcohol in the mix. i had to go over the short block twice because of that.
