Ls1/LSX main studs?
Old Apr 20, 2008 | 02:38 PM
n20stroker's Avatar
Default Ls1/LSX main studs?
Will arp ls1 main studs work in an Lsx block?
I see that TSP has 2 diff part # on there web site.
Old Apr 20, 2008 | 04:37 PM
KCS's Avatar
KCS
Moderator
There is a revised ARP main stud for the LSX blocks. One part number uses a 17mm nut, and the other uses a 16mm nut. The smaller nut is what you are gonna want to use for the LSX block because the holes for the main stud/bolts are closer to eachother than the OE LS series blocks.
Old Apr 22, 2008 | 11:48 AM
LSX Wizard's Avatar
The LSX block uses the same bolt spacing and same fastener sizes as the LS7 and LS9.
Old Apr 22, 2008 | 12:41 PM
Noyzee's Avatar
8 second mod
hm, i used my studs out of my ls2 block on my lsx. they are still in there.
Old Apr 22, 2008 | 08:09 PM
KCS's Avatar
KCS
Moderator
Ever built one?
Old Apr 22, 2008 | 11:19 PM
racer7088's Avatar
Yep they are the same ones. They are closer together like KCS says so the really big ones don't work that well. The 234-5608 has been revised several times now.
Old May 2, 2008 | 01:46 PM
LSX Wizard's Avatar
Ever built one?
Yes I have.
