LS2 intake , but need a throttle Cable " BRACKET"
Old Apr 22, 2008 | 09:29 PM
BadLtBlu99TA's Avatar
Arrow LS2 intake , but need a throttle Cable " BRACKET"
do you know who makes a throttle cable Bracket for these ls2 intakes since its all an electric TB ? and when you switch over to a TB cable driven the LS1 intake bracket wont work , would could i get one that will work for the LS2 intakes ? any info would be appriciated .. thanks !!
Old Apr 22, 2008 | 09:40 PM
vaticano's Avatar
http://www.sdparts.com/catalog/lsgen...ottleBody.aspx
Old Apr 22, 2008 | 10:07 PM
theblur98ss's Avatar
http://jjsautomotiveracing.com/holle...tlebodies.aspx
I'm in the same boat and it looks like the holley tb is the best option
Old Apr 23, 2008 | 05:10 PM
Arrow
the only tthing i really need is the Throttle Cable Bracket that is able to bolt up to the LS2 intake ... i dont need a whole new TB i have a 90mm UMI . thanks
Old Apr 23, 2008 | 05:22 PM
White_Hawk's Avatar
SLP sells an adapter for the L76, is it the same thing?
-Geoff
Old Apr 23, 2008 | 05:43 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
We stock an adapter that is like a spacer between the intake and TB....you then just transfer the bracket from your LS6 intake over to this and it bolts right up! It's about $100.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
