problems with lsx 454 please help!!!
What is the rest of your PCV setup? Could be a bad PCV valve, I have seen something similar with a bad PCV, but with your breather I am not sure what you are running for the rest of it...
What lifters where you using that failed? Who is your builder and what do they say? What lifter preload are you using? Could the cam timing be off, was the cam degree'd?
Basically, more info please... heheh
I personally broke this engine in on the dyno with proper oil & additives for best results. This engine made unbelieveable power on the engine dyno & worked well for months in the GTO making something over 550rwhp in your GTO.
Sorry for the Caddy lifter failing on you, but I got you new lifters, new gaskets & new intake valves on the cylinder that failed.
I never want anyone to have issues with a long-block, but a engine that smoked very very little out of the breather going to crazy smoking after it was taken apart points to something fairly simple IMHO.
I'm not suprised the engine had a hurt valve & retainer after the lifter failed. We had discussed with you that it was important for you to check the valvetrain immediately. Instead of checking the valvetrain & lifters you decided to just demand a set of lifters that weren't installed for several months. We shipped you new caddy lifters 2 months before you ever checked the lifter in the motor & found out it was damaged.
The issue is if a lifter fails you don't typically want to drive around on it for 2 months.
That being said I don't see how the lifter failure would have anything to do with a motor not smoking out the breather before it was taken apart, and then suddenly smoking. Hopefully we'll find something simple & get that thing running for you!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Is that the same one that collapsed the rocker?
-Geoff
