can you help me
Old May 27, 2008 | 03:34 AM
DASHTI's Avatar
Default can you help me
i want c5r heads 11 degree ls7 with 2.250 intake valve di and 1.650 ex. di intake flow 430+ 50cc Combustion champers its will be 14.5 compression ( the pore size is 4.200in. ) with 454cui . and -8cc piston the valve is titanum for the int. and ex . with pead locks grove and titanum retainer and super 7degree captiv locks the valve tip .290 to .330 tip lengthe with insert tips on the top valve tip .
with spring 1.625 in for the valve lift nearlly 1000 . and i want rocker arm shaft from jesel pro serise 1.85:1 and we need from you solid roller cam shaft with this grinde int. lift .980int.941ex. with dur.284 @ 50 int and .304 @ 50 ex. with lap 110 we need also valve cover gm performance and we need intake manifold to fits with this heads dimonitor flinge 4500 single carp for short deck block 9.260in. note: ( the heads 6 bolt for LSX iron with 1/2 in. ARPstuds kit and cooper titan head gaskets FROM YOU )
THANKS.
Old May 27, 2008 | 11:21 PM
Richard@WCCH's Avatar
The best castings to start with haven't been produced yet. Ask this in about a year and you'll get a lot more answers. At is stands the best heads are canted valve heads from ETP. The best wedge heads are made by All Pro. Both are available in 6 bolt configuration. IMO neither is really the appropriate choice for what you are looking for. I'm sure there are other opinons though.
Good luck,
Richard
