LS2 402 SES code-crankshaft position sensor
Every now and then the car will feel sluggish, almost like it is running on 7 cylinders or like its a 6 speed car going 20mph in 5th or 6th gear. It will typically go away if I open the throttle up for a second.
Upon ignition, the starter will drag for a bit with some backfiring before it will actually start-this has happend about 4 times.
Oil consumption issues. This car goes through oil pretty ridiculously. I am going to invest in a catch can setup but it is hard to believe that the lack of a catch can could use up 5 quarts of oil in less than 1000 miles.
Could all these be from the crank position sensor or might it only be causing a few of the issues? Thanks
I recently installed a Cheap catch can that I had lying around, and it helped. I will deffinately invest in a quality product. Strokers are known for more crankcase pressures from my understanding.
Can you post the codes you are getting? Did you do a CrankShaft relear procedure after the swap?
That is lot of oil consumption. Is there gas in the oil? I would check for leaks around the front and rear seals or any place obvious. Have you datalogged the car, if so what are you seeing?
