damn stock rockers. Is there an adjustable l92 rocker out yet? I noticed some more damn valvetrain noise, so i took off the valve covers and found an exhaust rocker had come appart spilling the needle bearings. (found 28 of the needle bearings)The stock rocker arms blow. Where can I get a set of adjustable l92 roller rocker arms without paying over 1 grand on jessels? |
You could always have your stock ones reworked. |
yella terra's are about 400-450 i believe |
New Era $420 for YT's. |
were they used, and u reinstalled as exhaust rockers when u put on the l92's? |
Yella Terras are a great brand. Give them a try. |
Send your stockers to Harland Sharp for rebuild. They will replace the bearning assembly with a much better design which will not fall apart. They clean them up ( look brand new ) and include new mounting hardware It will cost you much less than aftermarket rockers. We have sent several sets to them and have been more than satisfied with the results. Ryan |
Originally Posted by flyin ryan
(Post 9670157)
I run the YT Ultralights on mine. Nice rockers. |
I believe we have the YT in stock! I haven't seen them fail, but I've talked to guys that have seen it fail. :( |
In all honesty, the harland sharp mod is your best bet. I'm running a pretty nasty cam with close to .7" lift and the modded stockers are holding up JUST fine =D Mine are LS7 rockers as well... |
Originally Posted by NemeSS
(Post 9668461)
Originally Posted by JayplaySS2
(Post 9668173)
© 2024 MH Sub I, LLC dba Internet Brands
