flywheel dowel pin/allignment pin missing?
Old Jul 18, 2008 | 01:49 PM
2000ws6transam's Avatar
Default flywheel dowel pin/allignment pin missing?
Ok there is a hole in the crank and a hole in the flywheel is there some kind of pin that goes in it ?? "ordered" one for the GM dealership and i get the dowel pin that goes in the outter part of the flywheel to allign the clutch onto it he looked up different years and part # with no luck ...any ideas im gonna guess its about a 20 mm
Old Jul 18, 2008 | 01:54 PM
LS1MCSS's Avatar
No pin. It's just a hole to look at so you put the flywheel back on the same each time.
Old Jul 18, 2008 | 06:41 PM
fast377's Avatar
Yep. Kind of freaked me out the first time I did a clutch swap and took the flywheel off.
