TFS on 08 Ls3 Vette?
The question in hand is has anyone made good power on a LS3 with a combo like this?
it must be because you guys think the L92 heads are realy good. That's true, but I still think there would be gains by going to the TFS' and of course the cam is a no brainer
Seems a waste to spend the money on a set off heads that probably wont get you much if any.
That's like saying if u have a Ls6 Vette and u put TFS 215 heads and a ported Fast it would not gain much power because the ls6 heads flow just fine for a 346 , a couple mave made over 500 wheel with the Trickflows. All i'm saying is there anyone that has hard evidence they will not make more power than the stock L92's! I for one do not think its worth the money but he does and would like to see some hard proof he wasting his money.
The TFS will loose from 5000-7000, but pick up with the small runners below 4000.
Its a trade off. Big port, big power/big RPM, small port, good midrange, less overall HP.
You wont make 520 rwhp with a heads/mid 230s cam with a cathedral port on an LS3, nor will it make 485 rwtq.
Tell him to try it. I have, and its not worth the money in the heads/intake.
Louis
To all, take in mind that i am learning also.
Its all the same 205 vs 225 vs 235 argument- 205s make killer low to midrange power, but will not make as much as say a 225 up top. However, down low, the 225 will not perform like the 205.
Same goes for the 225/235 vs the LS3 head. You cant measure throttle response and snappiness of combo on a dyno. Thats where the cathedral port will win, but pure power, it would have to be a pretty radical setup to match that of the LS3.
Its just physics. You need to look at YOUR combo, and what YOU want to do with it. Bigger isnt always better, but HP/Dollar, if you have an LS3, throw a cam in it and save the 3500 for a good set of heads/ported FAST AND the FAST firewall mod.
I've heard power cuts off around 6300 w/LS3 manifold. A better cam that works up to 7K rpm should give you better results with TFS heads and 90mm manifold based on my research.
Amen, after LG pops in with thier personal advice not selling anything, hell shut the thread down.
LS3/L92's are the future so the intakes will catch up. I am going LS3 topend/cam and not looking back. Hell, you cant beat mild cams and 500+rwhp.
