lean LS7, should I be concerned?
Pull your plugs, if the plugs looks clean, then you're in the clear. Then do a leak down test and compression test to make sure there isn't any outliers that may point to a ring problem.
By | 2026-05-12 18:06:42
By | 2026-05-07 18:44:57
By | 2026-04-21 13:57:02
By | 2026-04-16 10:05:15
By | 2026-03-24 18:57:52
By | 2026-03-23 18:53:41
By | 2026-03-09 18:08:45
By | 2026-01-28 18:10:11
