Vic Jr+L92 heads= Possible??
Old Aug 2, 2008 | 11:37 AM
SVT THIS's Avatar
Default Vic Jr+L92 heads= Possible??
Will a Vic Jr intake work with the L92 heads? I knew due to the cathedral port designs I would be stuck with the L76 intake but I feel like I am hurting for power NA and was curious if this was an option. I may end up going to a diff set of heads if I cannot wake these up.
Old Aug 2, 2008 | 11:56 AM
CRAZYCUTER4.8's Avatar
Gm Makes A L92 Vic Jr Style Intake To Fit The L92 Heads, You Will Just Need To Have The Fuel Injector Bungs Drilled Out At The Machine Shop We Have Don 1 Already & In The Process Of A Second One.....
Old Aug 2, 2008 | 01:55 PM
greinder03's Avatar
gm actually makes an l92 efi carb intake. so you dont have to drill injectors
Old Aug 2, 2008 | 04:41 PM
See5's Avatar
Can drill and use injectors or not and mount carb. MSD makes a cheap box to run ignition with just crank and cam sensor.
Old Aug 3, 2008 | 12:05 AM
firefighting1101's Avatar
i was going to go that route...i had the gmpp l92 carb intake with the injector bungs already drilled with a 4 barrel throttle body...its a very nice setup.
Old Aug 4, 2008 | 11:13 AM
SIC LSX's Avatar
when i find a stock 6.0 i will be doing l92 heads and gm or vic jr intake. Im sure edelbrock will have one soon
