eagle crank question
Old Aug 2, 2008 | 03:40 PM
BigDB's Avatar
Default eagle crank question
the stroker crank doesnt have a key way on the snout. How am I supposed to line up the crank pully without a key way on the snout? Its a LS2 block BTW
Old Aug 2, 2008 | 05:31 PM
See5's Avatar
It really does not matter where it goes other than the pulley is more secure if pinned. The crank sensor fires off the reluctor.
Old May 28, 2016 | 04:26 PM
stage274's Avatar
Um, I just bought an ATI balancer, and pulled my old balancer off. I am supposed to have a 383 with an eagle 4 inch crank. I looked at my crank, and I dont have a freaking key way... When I bought the eagle 4 inch crank, I could swear to GOD, it had a key way in it. There are numbers on the nose which state 417. I dont know what that means. I really hope I have a forge crank in my car, because I swear I had a key way... Seeing this post, do eagle stoked cranks come with a key way? Also, my bill states, eagle stroker crank, because they had to machine the pistons to fit. Again, I swear when I bought the damn thing, it had a key way. Any help here, will be appreciated.
Old May 28, 2016 | 04:55 PM
sandragnx's Avatar
There is no key way on eagle cranks for balancer.There is one for the oil pump drive/timing chain sprocket.
Old May 28, 2016 | 05:13 PM
stage274's Avatar
ah... That is right, damn, I thought I had a key all this time. I thought I seen it, but that for the pump. I would have not gone with eagle then. They should have included it.. Thanks man, I was very nervous, that the machine shop messed up... I just have to pin it..
Old May 28, 2016 | 08:10 PM
64post's Avatar
Be sure to tighten your damper to spec,NOT just tight as you can get it. If the bolt manufacture (ARP) says 235 then tighten it to 235. Without a woddruf key the damper can spin/move on the crank if it's not brutally tight and you have any kind of "power. You almost certainly have to drop the starter and use a flywheel lock to do this if your motor is in the car. If you're on a build stand then there are other ways to lock the crank up.
Old May 28, 2016 | 08:56 PM
stage274's Avatar
Yeah for sure, I will need to pin it actually. Have an F1A.. I am kinda pissed eagle does not have a provision for a key.
Old May 29, 2016 | 11:17 AM
64post's Avatar
Pinning it would be the wise thing to do.
 Michael S. Palmer
