Need help identifying 0821 heads
Old Aug 4, 2008 | 03:09 PM
QUEST4-10S's Avatar
Default Need help identifying 0821 heads
I purchased these heads off some a while back, told me they were LS3 heads. I am currently disassembling a L92 off an 07 Caddy that has 5364 head castings. The difference I see is the exhaust ports on the 0821 heads are slightly larger. Need help identifying the heads and where can I find flow numbers from these heads.
Old Oct 6, 2008 | 01:53 PM
GRFMotorsports's Avatar
From what I have found the 0821 casting is the same as the 823 L92 head. If it has the hollow valves in it then it is an LS3 head. I have seen both an 0821 and 821 on the pad below the valve cover.
