Would you sacrifice weight for cubic inch?
For instance, would you get a 408 iron block over a 383 allum? Would you sacrifice 100 lbs for an extra 25 cubic inches? Is it worth it?
Im trying to get a new block right now and texas-speed has both of those for about $100 difference and I just wanted to get you guys imput before I decide on purchasing one.
-its stronger
-if something happened, i could bore it over some, can't with a aluminum
-i went for the extra cubes over the weight, I'm looking at aftermarket K members right now before i drop the engine in and later on I'll do the A arms too. That will save some weight.
Many would argue that the extra weight isnt worth it, but when you add the cost of a sleeved block opposed to a lq4, or lsx block, it becomes way more appealing to add 100lbs for the $/hp you're acheiving.
Why not just go 402 or 418 ci?
edit:
id just personally spend a little more and get a 402 or 418..
also I noticed you have a vette... Id never do such a thing in a vette.. for some reason im very against the 408, iron blocks I dunno how cheaper they are from 418s but Id rather spend the money and get a larger bore 418 and still weights 100lbs less... well worth it IMO...
what are you gonna use your car for anyways? drag? daily driver?
Part of me believes in that whole iron block should not be in a Corvette, thats why I am asking this question. But maybe forking out a couple extra bucks for the 402 wouldnt be a bad idea!
The iron block is stronger, which may or may not matter for what you want to do, but the first motor I blew up was iron, and since the valve that broke chipped the block, I got to buy a new one anyway.
Iron is stronger, but so what? he isnt going to be using FI or anything crazy... The Aluminum blocks hold up just right... If im not mistaken havent they taken a twin turbo aluminum LS7 in the 2000fwhp area??? I could be wrong...
lastly, aluminum can also be fixed, it just is more work, it has to be resleeved.. you guys are making it look like aluminum can never be fixed...
So,
if he went with a 402 he will make close enough power to a 408... 418 is even better, bigger bore than 408 and lighter...
I personally wouldnt sacrifice the weight in my F body, So no way in hell would I in a vette...
