427 gto
Old Aug 13, 2008 | 11:04 AM
McNair06Goat's Avatar
Default 427 gto
looking to find out everything i will need to do a l92 427 build on a ls2 gto. Need to know what i need to do the swap and who to get the short block and heads from... it dont have to be a l92 block but the price is right.
__________________
Old Aug 13, 2008 | 11:19 AM
Stang's Bane's Avatar
__________________
If you want a 427, there are 2 ways to do it right.
L92 block and "other"
Other consists of lsx,ls7, resleeved ls2, warhawk, dart. That is in the order of most expensive.
The l92 block has a smaller bore, but longer stroke. You are somewhat limited by the head choice in those, but they are cheaper.
What are your goals out of the car and do you have a budget, and if you do, what do you plan on getting for your money. IE, long block, complete engine, etc...
Old Aug 13, 2008 | 07:39 PM
njc.corp's Avatar
i am doing the same engine now- i got the l92 heads off richard at WCCH and some other parts from fraser at speed inc-
i am using a lsx short and usual h beams and forged pistions-
Thanks
Nick--
Old Aug 13, 2008 | 08:06 PM
RedDemonLsX's Avatar
You forgot to mention the LS3
Im getting mine from texas speed next week..
Old Aug 14, 2008 | 03:02 AM
99blancoSS's Avatar
The LS3 is the L92..
https://ls1tech.com/forums/generation-iv-internal-engine/499059-ls3-l92-info.html
As Stangs Bane said there are a few ways to do a 427 these days and it all depends on your budget. The bigger the bore the more the cost of the block. You can use an L92/LS3 block and go with a 4.100" stroke crank. This is the least expensive 427. Then you have a 4.125 bore with a 4" stroke in the LS7 block or you can have an ls2 re-sleeved. These are the 3 more popular 427 builds, then you have the more expensive cylinder blocks and so forth. Some people don't like the sleeves in the ls7 block and chose the later
We could set you up with a few different combinations to make a 427, all depends on your budget.
I'll pm you with some options on short blocks as well as heads.
Old Aug 14, 2008 | 07:23 AM
Originally Posted by 99blancoSS
Damn,i did not know that..
Wonder why the 418ci is listed as a L92 block,and the 427ci is listed as the LS3 block..
A little confusing
Thanks for the info
Old Aug 14, 2008 | 09:12 AM
im looking for the complete build to be about 8 to 10k range would like to have the LSX because i could go with FI later with no problem but it is still pretty heavy...
Old Aug 14, 2008 | 09:37 AM
05JUDGE's Avatar
I've got less than $8k in my L92 427 stroker from Texas Speed. You'll have a 10sec car pretty much regardless what you do to it. I've only made it to the track with my car once so far and managed an 11.52 and I'm at 3670elevation and a DA of 5527ft. That's 10sec almost anywhere else. I can sure tell you that you can't go wrong with Texas Speed. They have some great service and great prices.
Also you don't need anything special. It's a direct bolt-in replacement. Keep all the accessories off your motor and put it all together on the new one. Simple as that. Then you can sell your old one and pay for your other goodies.
Old Aug 18, 2008 | 10:05 PM
LS2tiger's Avatar
You should get ahold of Ron at Vengeance They have done a bunch and could come close to your price point.
Old Aug 19, 2008 | 08:35 AM
LS2tiger, they do the buildup or do they have a different shop do their builds because i was thinking of h&k, LME, or Weber to do the build for me...
Old Aug 19, 2008 | 08:39 AM
and by the way i remember you last year at the titans parking lot get together i was the only orange goat there
Old Aug 19, 2008 | 09:42 PM
LS2tiger's Avatar
Yep, I remember you. I'm not sure who builds their engines. I know they did my 454 and I couldnt be happier. ( well I could but I couldnt afford it)
Where you planning on installing it yourself ?
Old Aug 20, 2008 | 09:25 AM
yep i have the ls2 out now on a engine stand. my buddy is going to help me with the install i of coarse doing most of the work
Old Aug 20, 2008 | 09:28 AM
im thinking im going to do a 427 lsx with some gm casting heads worked over of coarse, but i am still doing my homework
