Who can spec the "RIGHT" cam for this???
Old Aug 19, 2008 | 11:58 AM
HTMtrSprt's Avatar
Heath,
The cam you described (248/260-112) should work very well actually..... with 2 minor changes. Put a little less lift in the intake (.570-.580") and a little more on the exhaust (.650-.670") and it should work great.
Brian
HiTech Motorsport
Old Aug 19, 2008 | 02:12 PM
Qwiknotch's Avatar
Originally Posted by 3timeracin
I dont work for comp or thunder but did work for west tech and tested about 800+ engines in the last 3 years. I am tesing on my own now and have been getting deep on the l92 stuff with 4 cars going now. tuning has been a nightmare as I am not a great tuner.
I would try something like this 240/252 on a 112 installed on a 108ic
when you are done paying to get some other recomendations lets see how close I am ?
I KNOW OF 3 CARS RUNNING THIS CAM 246/260 111LS WITH 416 AND RUNNING HIGH NINES NA AT 3200LBS AND 4.11 GEARS ?
West Tech in Fontana? Who is this?
Comp does damn good at grinding cams. I would also recommend going with more on the exhaust as these Ls engines have characteristics really similar to a sbf(gasp!) and they like 10-20 more lift on the exhaust as well as 8-10 degree split duration cams.
Chevy High did a story a little while back on a 402" LS2 with unported Dart 225's, victor jr intake, 11:1 compression and a 600lift hydraulic roller and it made 583hp and 530tq. Here is the link:
http://www.chevyhiperformance.com/te...ests/dyno.html
the cam was
Manufacturer Comp Cams
Part Number 54-448-11
Type Hydraulic roller
Valve lift 0.605/0.609 inch, intake/exhaust(factory rockers)
Duration at 0.050 238/240 degrees, intake/exhaust
Lobe separation 112 degrees
Old Aug 19, 2008 | 08:08 PM
LSXS10's Avatar
Hey guys, my L92's and intake are for sale.. Im going back to a set of cathedral heads, i already have some stuff for them. Anybody that wants them they will be in the for sale thread tommorow nite
Old Aug 19, 2008 | 09:35 PM
cam75w/ls1's Avatar
Damn! I was hoping you and I were going to be the only L92 headed S10s around. In case you change your mind,this what I ordered for mine.
Attached Thumbnails Who can spec the "RIGHT" cam for this???-s10-parts-007.5.jpg
Old Aug 19, 2008 | 10:39 PM
Patrick G's Avatar
LS1 Tech Administrator
Originally Posted by LSXS10
How many of the L92 cams have you done that are not for a dd. What kind if results and numbers have they produced?
Check out this L92 headed F-body. It runs 9s NA.
https://ls1tech.com/forums/drag-racing-results/901758-hit-9-s-n-pump-gas-l92-heads.html
248/262 .615”/.595” 108LSA +2 advance cam. Single plane intake 454LSX with carburetor.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
