Good combination? Yes or No?
Old Aug 22, 2008 | 05:01 PM
DomesticAbuse's Avatar
Default Good combination? Yes or No?
Here's my final conclusion on what I should buy for my ported L92 heads. Since the engine will be boosted I don't want the lift on the cam to be too high. So I think I'm going to stick with a set of 1.7 roller rockers. I've been told that even though a set of 1.8's won't put my 595/608 lift cam over the heads .660" max lift I still don't think I need the extra lift. I've seen a lot of people are using the yella tella rockers for the L92 heads, is this a good route to take? I've also been told that I should go with a set of 7.4 hardened push rods, maybe from Comp cams. And finish it off with a set of LS7 lifters. Let me know what you think. I'm hoping I can get these parts for under $700. Does anyone know where I can find the best deals on these parts? Thanks
