ARP head studs
Old Aug 23, 2008 | 12:59 PM
Big Bird WS6's Avatar
Default ARP head studs
there is two head stud kits for ls based cars. which kit do i need for an LS3?
thanks guys
Old Aug 23, 2008 | 01:30 PM
Tom@SpeedInc's Avatar
ARP234-4317
http://www.speedinc.com/cont.cfm?cid=C0000187
Old Aug 24, 2008 | 10:46 PM
Jeff@TotalPerformanceEng's Avatar
I have a set that I used on my NA setup for 1974 miles. Being that they are studs, you can re-use them as much a you want. Mine were only used once.
The ONLY reason I am selling them, is because i'm boosting my motor, and going with TFS 6 bolt heads and L19 studs.
Mine are currently at LME. I'll take 200 shipped for them.. This saves you about 60 bucks.
My set includes the studs, washers, and 12point nuts.
No matter what you do, just make sure they a the Gen 2 studs. Which means they are for 2004 and later motors..
Originally Posted by Fraser@SpeedInc
Old Aug 25, 2008 | 02:06 PM
ssmith512's Avatar
Would ARP studs or regular ARP bolts be recommended for an N/A motor?? (Motor will never see boost or spray - just a mild N/A 500RWHP 406)
Steve
Old Aug 25, 2008 | 04:28 PM
If you have any intentions of removing your heads then studs are best. But in your case, ARP bolts will be just fine.
Steve
Old Aug 25, 2008 | 04:40 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
As a note, I'd much prefer to use a bolt instead of a stud in an F-body for install ease. If you're pushing it to the limits, the stud is nice to have for more consistent load distributing and clamping...but for your average street/strip build the bolt is fine.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 25, 2008 | 07:06 PM
ssmith512's Avatar
Thanks!!!
Old Aug 25, 2008 | 07:13 PM
Not a bad offer but i can get them for 230 for new.
Old Aug 26, 2008 | 12:38 AM
Congrats...
Old Aug 26, 2008 | 07:28 AM
1ORANGEWS6's Avatar
What is the price on the L19 studs?
Old Aug 26, 2008 | 10:03 AM
L19? huh?
