C6 LS2 stroker questions
Old Sep 3, 2008 | 07:42 PM
JayplaySS's Avatar
Moderator
Default C6 LS2 stroker questions
Guys, if I kept my C6, what stroker would be good for 200 shot? I read some of the TSP 427's are not advised for Nitrous or FI. I just thought you guys with experience could help advise me.
Im looking for 500-530rwhp N/A but the ability to run a 200 shot.
It looks like TSP's LS3 418 stroker is my choice so far at only $4200 for the shortblock.
Any ideas?
Old Sep 4, 2008 | 10:51 AM
JayplaySS's Avatar
Moderator
Is anybody building a TSP 418?
Old Sep 4, 2008 | 01:15 PM
venom ws7's Avatar
Why dont you go with 402ci with your LS2 Block and good H/C/I Setup.
Old Sep 4, 2008 | 05:29 PM
JayplaySS's Avatar
Moderator
Im still trying to figure it out really. Few more cubes = few more horses.
Old Sep 4, 2008 | 05:37 PM
S0MWS6's Avatar
Bischoff Engines 418 is what I am running and the motor will take a 250 shot all day long
Old Sep 4, 2008 | 07:19 PM
JayplaySS's Avatar
Moderator
Originally Posted by S0MWS6
Bischoff Engines LS3 418 is what I am running and the motor will take a 250 shot all day long
Nice, anymore info on it? Any pics of your build?
Old Sep 5, 2008 | 08:33 AM
conkrete21's Avatar
Any ideas?
I'm having a custom built LSX455 for my C6. Don't plan to run any dope on it at first, but do plan on it a little later. I know for certain, this engine will swallow a 200 shot without even thinking about it.
Old Sep 5, 2008 | 09:21 AM
99blancoSS's Avatar
We do an LS3 416... 4.070 bore x 4" stroke you can juice is all day long if you want.
The reason a 427 is not a good idea for the power add is the 4.100 stroke.
A 416 with good heads will net the HP your looking for and be able to handle the spray. I'll pm you with some more information.
The 418 has been bored to a 4.080
Old Sep 5, 2008 | 09:49 AM
S0MWS6's Avatar
JayPlay here is my spec...sorry no pics at this time they were all on my old cellphone but i can get some..i do have an idle clip of it though
6.0 Iron Truck Block
Eagle 4.1" Crank
Eagle Rods
Ross Nitrous Pistons
TEA Stage 3 5.3 heads (Flowed ~330@.600)
Comp 236/248 .617/.617 112LSA Cam
Trick Flow Chromoly Pushrods
Yella Terra Shaft Mount Rockers
Comp Dual Springs
Titanium Retainers and Locks
ARP Head Studs
ARP Main Studs
Cometic Gaskets
Vic Jr Intake port matched to heads
Intakeelbows.com elbow
90mm FAST Throttle Body
Compression is 10.8:1 if i recall. Should make around 630-640hp at the crank on pump gas.
Old Sep 5, 2008 | 08:54 PM
JayplaySS's Avatar
Moderator
Eagle 4.1" Crank
Eagle Rods
Comp Dual Springs
ARP Head Studs
ARP Main Studs
Cometic Gaskets
Great set up. That cam is a bit too big for my needs (A6) but thanks for the info, it helps me decide.
Old Sep 5, 2008 | 08:56 PM
JayplaySS's Avatar
Moderator
Please do. I am looking at a strong shortblock and N20 vs $$$ for a strong shortblock and SC/Turbo.
So the 416 (4" stroke) will swallow a 150-200 shot with no problems? Nice.
Old Sep 5, 2008 | 08:57 PM
JayplaySS's Avatar
Moderator
Thats alot of cash my friend but wicked set up no doubt.
Old Sep 6, 2008 | 12:12 PM
conkrete21's Avatar
Thanks man... It should be completely built, installed and tuned by the 25th/26th of this month.
Old Sep 6, 2008 | 01:18 PM
Fifedogg's Avatar
I will be putting a 200 shot on my car very soon
Old Sep 6, 2008 | 01:27 PM
99blancoSS's Avatar
Ineresting. Tell us about the build what stroke and bore
Old Sep 6, 2008 | 01:33 PM
99blancoSS's Avatar
pm'ed you. Basicaly the n2o and boosted block is the same, the n/a block can be different.
We dont recommned anything bigger than a 4" stroke for a power add due to the sleeve length.
Also for a power add iron is always better than aluminum. Aluminum expands at a quicker rate than iron/steel does. The iron block will be more durable.
Our 434 is for big FI applications. 1500-2000 hp.
The 408 will handle all you can throw at it as well so really it alld epend on how much power you are looking to make. Bigger cubes make bigger power. BUT our 454 is for non power add applications.
We go 4.155 x 4" stroke for power add and 4.185 x 4.100 for n/a on the LSX block.
You could have a 416 at 550 rwhp before you hit it with a 200 shot and be fine. Obviously anything you can do with aluminum you can do with iron
So it's all about budget really. A s/c or turbo will cost more than a nitrous setup but the shortblock cost is the same.
Old Sep 6, 2008 | 02:53 PM
conkrete21's Avatar
New GM LSX block
Callies 4.250 forged crankshaft
Callies Compstar 6.100 rods with ARP 2000 rod bolts
Custom 4.130 Diamond pistons/ total seal piston rings
ACL Race main and rod Bearings
World Products (Warhawk LSX) 235cc heads (ported by ARD)
Custom ground Comp Cam billet core
Comp cams comp R lifters
Comp cams Chromemoly pushrods
Melling high flow oil pump
ARP LSX head studs ARP 2000 material
Rollmaster timing chain
Cometic custom head gaskets
gaskets - (oil pan, front cover, valley pan, header gaskets)
NGK sparg plugs TR6
Spec stage 4F full face disk and pressure plate
Spec aluminium flywheel
New GM slave cylinder/ and throw out bearing
Old Sep 6, 2008 | 04:22 PM
99blancoSS's Avatar
Nice, similar to my build, 4.135 bore x 4.250 stroke for a 457. I'm using a sleeved LS2 block.
Old Sep 6, 2008 | 04:25 PM
conkrete21's Avatar
Have you completed the engine as of yet? If so, what were the final numbers. I'm more interested in torque and when it comes on. Ideally (for me), it peaks early (2400-2600rpms), but continues to pull aggresively through 7,000rpms.
Did you happen to use a 235cc head as well? What was the cam you chose?
Old Sep 7, 2008 | 12:37 AM
JayplaySS's Avatar
Moderator
This does seem to be the best $$$ route to go. Does anyone have any advice between the TSP 402 or the Livernois 404 kit? I will need to find a local South Florida shop to assemble the shortblock. Any advice?
