questions regarding ETP heads
Old Sep 13, 2008 | 04:21 AM
1dirtyZ's Avatar
Default questions regarding ETP heads
just wondering if you need special rockers to work with the ETP ls7 style heads or can you use the stock ls7 ones? and do you need special pistons (i.e. different valve pocket location ) to use these heads?
thanks
Old Sep 13, 2008 | 07:15 PM
ssmith512's Avatar
I use the stock LS7 rockers on my ETP 4" bore LS7 style heads. The stock valve covers need to have the baffles removed though for clearance. You will need the ETP rocker stands. Not sure about valve pocket location. My pistons are a full dish. I would bet though that different valve pocket locations would be needed. They are 11 degree heads with awful big intake valves.
