Lunati Pro Mod Rod Bolts
Old Sep 14, 2008 | 12:43 AM
67Firebird455's Avatar
Default Lunati Pro Mod Rod Bolts
They've been used once, can I re-use them, or do I need replacements? They're supposedly 220,000psi 7/16" bolts, not sure if they're meant to stretch or not, but would like a definitive answer. Thanks fellas.
Tony
Old Sep 14, 2008 | 09:41 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
You can use those several times, I doubt you'd ever need to replace those particular bolts either. I believe the torque spec is something like 73lb ft with ARP lube.
Old Sep 15, 2008 | 11:27 AM
Right on, appreciate the response. =)
