Head Gasket and Boost
Old Sep 17, 2008 | 09:50 AM
Big Bird WS6's Avatar
Default Head Gasket and Boost
which is beter Cometic or the new GM 5 layer head gasket.
motor will have around 1000 horse and 18psi?
thanks
devin
Old Sep 19, 2008 | 09:09 PM
JPH's Avatar
JPH
I would use COMETIC myself. I use there stuff alot on N/A and FI motors. Just make sure you prep(clean/correct surface finish 50ra)ALL surfaces well before installation and maybe spray alittle haloymar on them for added sealing and ALL fasters get torqued and cycled properly?
Old Sep 22, 2008 | 10:52 AM
Fireball's Avatar
I have the 5-layer GM MLS and it didn't start pushing water until I crossed ~1300 hp and 20-21 psi...but...I have alot of ignition timing
even then, its only pushing a few ounces...
Old Sep 22, 2008 | 12:18 PM
1.8t's Avatar
^ What bolt heads are you running?
Old Sep 22, 2008 | 01:29 PM
thunder550's Avatar
High on diesel fumes
Stock MLS gaskets are some of the best you can get IMO. Jsut make sure you use good head studs to keep everything clamped together.
Old Sep 22, 2008 | 02:46 PM
Fireball's Avatar
std ARP studs
