Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
Coil and wire Combo Sale
Old Aug 2, 2013 | 12:59 PM
granatelli sales's Avatar
Default Coil and wire Combo Sale
You will not Find a better wire and coil pack combo
$635
- Fits 2005 - Present GM Cars
- Works with LS2, LS3, LS7, LS9, LSA, L92, L99, and L76's
- Direct OEM replacement with a simple plug and play, won't void your factory warranty
- Improves fuel economy, throttle response, and idle characteristics.
- Increased engine efficiency with improved engine combustion
- Gains of up to 12hp have been seen with these coils over stock. Average gain with no other changes is 6 to 8hp on an otherwise stock vehicle. Gains of up to 18hp have been experienced on heavily modified forced induction applications.
- Rated at 80K Volts, Pro-Series Extreme coil packs offer nearly twice the voltage over the competition.
- Lifetime Warranty
- 8 Coil Packs included in a set
Direct OEM replacement, exceeds OEM specifications, OBD-II computer safe
Increase power to the spark plug up to 400% over stock
Customers have reported up to 15HP (normally aspirated) & 35HP (s/c, turbo, & nitrous). Average gains on an otherwise stock motor are 5hp N/A and 12 to 15 with factory forced induction
0 Ohm resistance, no RFI / EMI interference thanks to patented protector ring
Patented* design works with all fuel injection systems, street cars and race cars
Solid stainless connector cable with stainless snap lock spark plug connectors
High temperature silicone boots, 8MM jacket with fiberglass-reinforced braid resists temperatures up to 500 degrees f (1200 degree f. boots optional).
Ideal for use with aftermarket headers and/or turbocharger systems
Includes all necessary hardware
Over 600 fitments!
* Granatelli O ohm wires are patent protected by United States Patent number 7,185,622. This patent covers our unique method of producing ignition wires of extremely low resistance while maintaining very high noise suppression. The benefit of this invention is that full electrical energy from the ignition source is transmitted to the spark plug. The end result of the application of this method is increased horsepower, torque and fuel economy.
Old Aug 7, 2013 | 12:35 PM
Old Aug 27, 2013 | 06:21 PM
Attachment 726791
Old Aug 29, 2013 | 02:51 PM
Here is what a Customer Said
Originally Posted by FBGSU02
I have not had this issue at all. These things are amazing. i have had MSD's, Delco's, Taylor's and none come close. Lifetime Warranty is all i can say. I have been driving my car a lot lately and no issues with electronics.
