Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
l83 vacuum
Old Nov 16, 2018 | 02:08 PM
greyskull's Avatar
Default l83 vacuum
Is there a port or area which I can pull vacuum for brakes on a l83? Installing the engine into a 63 impala.
Old Nov 16, 2018 | 04:15 PM
ANY port that goes straight to manifold vacuum will do.
Old Dec 8, 2018 | 11:31 PM
evldoer's Avatar
I used the port that the fuel tank evap goes to and have had no problems.
Old Dec 9, 2018 | 12:04 AM
If it's to assist braking it should be a decent sized port to supply enough vacuum to do the job at hand.
Old Dec 11, 2018 | 10:44 PM
Bryan McCall's Avatar
I don't know if the L83 has a vacuum pump, but if it doesn't I'll send you one for just shipping cost. I had to ditch the one off my LV3. I'ts just going to go in the shed and collect dust.
Bryan
Old Mar 6, 2019 | 05:11 PM
sloera55's Avatar
this is where i got mine
Old Mar 9, 2019 | 09:18 PM
f.flujan's Avatar
Default Vacuum
What plug/sensor did that read. If I do that do I need to let the person handling my wiring know
