Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
Fuel Injector codes issue
Old Jul 29, 2024 | 01:51 PM
Scarebird's Avatar
Default Fuel Injector codes issue
I have been plagued the last month with intermittent fuel injector faults. I Though tit was due to bad injectors. The ECM kept throwing DFI codes and the engine had a slight miss as it warmed up. Changed out the injectors made it worse. Had the car towed to a good local shop that fixes all. Turned out the injector harness connector to the main harness was not making a good enough connection. Tom replaced the harness and now runs fine.
Now to list it on BaT...
