Generation V Internal Engine 2013-20xx LT1
OBX individual throttle body
Old Jan 4, 2015 | 05:53 AM
rkreigh's Avatar
Default OBX individual throttle body
Has anyone seen these for the LSx engine? the obx stuff is a bargain and the quality looks to be pretty good
not sure if the LS3 head configuration is similar enough to adapt what they have to the LT1, it would take some hacking up and rewelding no doubt
hopefully the ITB for the new gen LT1 is under development
like to try putting a plenum at the end of each and do a twin turbo
probably won't make that much more power but I'm intrigued by it from a wow factor
Old Jan 14, 2015 | 09:57 AM
96 Comp T/A's Avatar
They aren't even close, unfortunately. I am sure somewhere, sometime a set will appear, but I wouldn't hold my breath.
Old Jan 14, 2015 | 02:05 PM
JustinEntropyRad's Avatar
OBX needs someone to come out with the product so they can reverse engineer it. I have used some of their stuff in the past, often with great success. Just take it for what it is, with reasonable expectations, and you will not be let down..make sure to properly torque everything!
