bad engine noise ls1 need help!!
http://m.youtube.com/watch?feature=youtu.be&v=NMlBQTWgzzE
You could pull all plugs and do a compression test or if you have the tools and know how- do a leak down test.
You can also drain the oil and see what it looks like. If you have the tool you can cut the oil filter and see if it has any debris in it.
Try running it as little as possible, You could do more damage that may cost more in the long run.
A compression test may help you narrow down where the problem might be, If you're not mechanically inclined I would try to get someone who is to help you diagnose the problem.
