Generation V Internal Engine 2013-20xx LT1
Delta PAG Fans
Old Mar 14, 2015 | 03:08 PM
CBAR02SLP's Avatar
Default Delta PAG Fans
Hey guys, Am interested in installing this Delta fan system in my '15 Silverado (with a Whipple blower!). Has any one used these fans, and if so, how did the controller and Chev ECU combine?
Thanks
Charlie
Old Mar 14, 2015 | 10:37 PM
Noah Burns's Avatar
What for?
Old Mar 16, 2015 | 11:16 PM
CBAR02SLP's Avatar
Default Delta Fans
Your reply was so detailed, I'll have to extrapolate...
The fan controller supplied with the blower only provides for the stock system to run all the time at full speed...I'd like to have the temp sensing system at a lower decibel level restored...
Old Mar 17, 2015 | 12:02 PM
Noah Burns's Avatar
that's what I was wondering, why you would want to upgrade on an already more than sufficient cooling system.
Old Mar 18, 2015 | 11:19 PM
CBAR02SLP's Avatar
The Whipple blower controller electronics runs the stock fans at full speed, all the time...
In an effort to reduce fan noise and restore "fans when you need them", I'm trying to see if the Delta system can be so integrated into the stock controller?...
Old Mar 19, 2015 | 06:33 AM
Higgs Boson's Avatar
You have control over the fans in the tune in the stock ECU. The more crap you add to your car the more problems you are going to introduce.
In other words, install the blower, tune the stock ECU, done.
Old Mar 19, 2015 | 09:15 AM
CBAR02SLP's Avatar
Default Delta Fans
Thanks, exactly what I originally thought...but for some reason, the Whipple controller won't allow this to happen?
Thanks for your replies anyway...
