Generation V Internal Engine 2013-20xx LT1
Possible Barbell Plug Leak?
Old May 24, 2015 | 02:01 PM
69-er's Avatar
Default Possible Barbell Plug Leak?
Does the inner plug on the barbell plug, the one with the ridges, completely seal the oil passage? I'm getting indications that oil is leaking past this plug thereby partially or mostly bypassing the filter.
Attached Thumbnails Possible Barbell Plug Leak?-ls-oil-system.jpg   Possible Barbell Plug Leak?-barbell-plug.gif
Old May 28, 2015 | 09:36 AM
64post's Avatar
Are you getting an oil leak from the back of the engine onto the ground?
Old May 28, 2015 | 05:46 PM
69-er's Avatar
No, just from the previously mentioned port. I assume you're thinking that the rear plug might be leaking. I have excellent oil pressure, so I think that one is secure. I wouldn't know if it's leaking anyway; as I understand it would just leak back into the oil pan.
This issue is probably one of those "problems" I think I have found when it's really not a problem at all. It's just that the guy I got the pre-lube procedure from didn't mention a leak. He hasn't answered my message to him either.
See:
https://ls1tech.com/forums/generatio...e-problem.html
Old May 28, 2015 | 11:09 PM
DietCoke's Avatar
irrelevant. oil bypasses the filter anyway, by design.
Old May 29, 2015 | 04:51 PM
69-er's Avatar
I believe only when it's clogged or the oil is cold and thick.
Old Jun 18, 2015 | 11:34 AM
5 Liter Eater's Avatar
Or the bypass spring oil pressure is reached.
