Gen V L83 oil pressure problem
I've developed an oil pressure issue on my 2016 Silverado. 5.3L Gen V aka L83.
This is a low mileage truck, as in 28000 miles. But I've done a lot of work to it so warranty is not an option. Trying to fix it myself.
The issue is the oil pressure stays on the high side and I'm throwing a code PO6DA.
I've already done the obvious and easy stuff. Oil is new, I change it frequently and only use quality parts. It has the dexos approved 0w-20 mobil1, and filter is A/C PF63E.
I've cleared the code several times and it keeps coming back. Additionally I can see the pressure is staying high. ie...its supposed to drop at idle and it is staying 40psi to 60psi all the time.
I'm having trouble finding information about the oil pressure regulation. I understand it is a 2 stage system. Specifically I'm pretty sure there is a solenoid that controls the high and low pressure.
When I look at brake downs I can see a solenoid on the front side of the pump/timing cover, but I can not find a part number for it.
When I spoke to the dealership they look at me like I've got a screw loose, which may be true but I'm all I've got, and I need to get this fixed.
I can find the P/N for the solenoid for the cam actuator but not the oil pump.
Does anyone here know what the part number is? I would like to try changing the solenoid.
I believe the part is called an oil pressure valve solenoid.
Thanks!!!
There is indeed a solenoid, it's called the flow control valve solenoid. The part is special order but is only like 20 bucks.
I decided to start pulling it apart before I ordered the part, and once I got into it I found a connector on the timing cover under the water pump out of sight and hard to get to, that the wires are broke. Almost looks like they were cut right at the connector, but I'm thinking what happened was these wires were stretched too tightly when the truck was assembled and after time they finally became fatigued and broke right at the connector.
Reason I say this is because the other ends of the wires are clear up into the harness and lack about 2 inches to reach the connector. Have to pull on them hard to make them reach. So if they were connected they had to be stretched very tight.
I'm going to have to solder some extensions to make them reach properly.
Anyway if anyone develops a code PO6DA might want to look carefully at the front wiring harness below the water pump, and behind the crank balancer area.
