Generation V Internal Engine 2013-20xx LT1
Starting and Running
Old Apr 24, 2018 | 02:46 PM
Superbee68104's Avatar
Default Starting and Running
I'm New to GM, I just pick this 1994 Pontiac Trans Am with and LT1 the Guy said that he got it from his cousin he put a CC503 Comp Cam lifters and roller rockers ran fine for about a month and then it just died one day acts like it not getting gas when i went to look at it the fuel pump was going up and down 42 to 20, when i started going though it i found a grounded wire coming from the coil fixed it, i noticed the the guy messed with the Rocker adjustment i set everything back to zero the car would not start i turn them all off a 1/4 turn it starts making a lot of rocker noise and is running rough Any ideas?
Old Apr 24, 2018 | 02:57 PM
This forum is aimed at 2013 and up LT-1's, not the old small block ones.
