Max Hp on Gen V LT1 Rods?
Ive changed a set out on a 17 Vette, they look to be similar in design as the Gen IV stuff thats known to handle around 700 reliably and pushed to the moon with a hail mary. I imagine they are similar in strength at least if not better. The LT1 crank is forged already I believe, no crank key tho.
Thanks for the information. Your car must be a beast!!
we all replace stock rods with appropriate rods for the application. why is this still a question in 2019? OP, i'm not picking a fight. either stick with a SBE, or chuck the dogshit stock parts of any OEM. IMO.
rod strength
Every stressed part on the Gen 5 engine has been designed by FEA (finite element analysis) making them a clean sheet design. not sure on the metallurgy on them. GM/Ford/BMW and the rest of them all shoot for a 25% increase on everything according to a Ford Powertrain engineer i know. it makes for great marketing.
Seems there is 2 different designs for Gen5, the 6.2 gets that strange looking one as I described above and 5.3 gets one similar to Gen4 with different bearing tab location. That 6.2 rod looks very stout, I’d wouldn’t be surprised to see it last high hp use.
the bearing tabs are interesting. not sure why the change, but there you go. in FEA, you can input your existing design and then just give it a percentage that you want the new part to exceed the previous one by within a given set of parameters. then the computer chugs for a week or a month, and it gives you the new design. it's almost like cheating.
The following users liked this post:
383z (07-05-2020)
we all make a good living. we should all ALSO be engine builders. who cares what power level(high rpm separation at TDC) a stock rod fails at.
G Atsma (01-04-2020)
The following 2 users liked this post by David@Vengeance:
383z (07-05-2020), Che70velle (07-29-2019)
Does the C7 Vette Z06 have an LT1 or LT4? I know it's a 6.2, but I wasn't sure if it was the same engine. In any case, I know someone who has a twin turbo C7 Z06 on stock internals. I haven't seen his dyno sheet, but I heard he is close to 1000 Whp. I have seen him runs 8's in the 1/4mi.
So, if you want to know how much hp a stock Gen.5 6.2L motor can handle, I would say enough. With a good tune, you should be safe at 800+ Whp.
That's an LT4
and they stay together at over 1k to the tires.
the lt4 has forged pistons and rods the lt1 doesnt weak point on lt1 are teh piston ringlands i think most builders agree on 700 hp before swapping pistons and rods if you dont want to change rods at least do the rod bolts as they are a big part of the rods hp rating
