Generation V Internal Engine 2013-20xx LT1
Gen V LT4 Flywheel Bolt Torque Specs
Old Feb 24, 2019 | 06:08 AM
Jkviper's Avatar
Default Gen V LT4 Flywheel Bolt Torque Specs
Hi,
Just looking to confirm flywheel bolt torque specs. I found theses specs on pace performance web site but the numbers seems low for the Gen V as compared to the Gen IV specs.
First pass 11 lb ft, 22 lb ft, third pass 45 degrees.
where the LS3 15 lb ft, 37 lb ft, 74 lb ft
thanks for the help
Old Feb 24, 2019 | 08:41 AM
Jkviper's Avatar
Actually I did confirm these are the correct specs. The last 45 degree turn really tightens up the the bolt to a torque similar to LS3
