Generation V Internal Engine 2013-20xx LT1
LV3 cam?
Old Aug 3, 2019 | 06:50 AM
FogOfWar's Avatar
Default LV3 cam?
Hi,
Does anyone knows anyone who knows anyone that can make me a custom cam for LV3. (Basically Gen 5 L83 with two cylinders chopped off).
There are no cores available, so the work must start from billet bar.
Any hints would be greatly appreciated!
Old Aug 3, 2019 | 10:53 AM
OR regrind a stock one. Check with Cam Motion.
Old Aug 3, 2019 | 11:56 AM
FogOfWar's Avatar
That's the last resort i'm trying to avoid as I need ~0.130 more lift and also quite a bit more duration, the base circle will be too small to my liking after the new lobe is situated inside the oem lobe. Also, new tempering is needed, as more that 0.06" is taken from the cam and induction hardened OEM-s are soft beyond that by my knowledge.
Old Aug 3, 2019 | 12:48 PM
What will this V6 be used for?
Old Aug 3, 2019 | 02:05 PM
FogOfWar's Avatar
Drag racing, so no prolonged use.
Old Feb 21, 2020 | 11:39 AM
sparrott's Avatar
Anything new on this? I have tried several vendors and either get "no thanks" on that project or no answer period. I am just looking for a way to remove the DOD/AFM for my LV3 that is going into my S10 rally truck.
Old Apr 3, 2020 | 11:14 AM
72poncho's Avatar
Any updates on this thread? Will be installing a LV3 into a MG midget for autocross and was seeing if there was anyone having luck with regrinds?
Old Apr 27, 2020 | 10:30 PM
Kenova's Avatar
Try http://jonescams.com/
Ken
 Michael S. Palmer
Old Sep 15, 2020 | 09:53 AM
FogOfWar's Avatar
I ended up with Delta cams regrind. I just purchased a new gm broomstick for use as core. It was less than shipping one over from europe.
Have not installed yet.
Old Jul 13, 2021 | 10:25 PM
Dewser312's Avatar
Fogofwar what was the cam specs after they reground the cam...
Old Jul 13, 2021 | 11:13 PM
He hasn't been here since he last posted, but you never know....
