Generation V Internal Engine 2013-20xx LT1
Rod Bolt Torque for Boostline
Old Aug 25, 2022 | 03:54 PM
dw456post's Avatar
Default Rod Bolt Torque for Boostline
Got a surprise today. After seeing a lot of different torque values for ARP 2000 rod bolts and none of them were the same as the supplier that I bought the rods from, I decided to call Wiseco and see what they said. I have the LS Boostline rods with 7/16" ARP 2000 bolts. however, found out that they are not the same as the standard ARP rod bolt. The torque value is 30 ft# plus 50 degrees. They are good for 3 uses. I have a digital torque wrench that measures angle as well as providing a torque number when you hit the specified angle and the torque was a lot more that I would have expected for a rod bolt. Numbers were consistent, so I guess it's good. The Wiseco rep refused to give me a final torque number and said to use the angle method and a stretch gauge. You can only buy these bolts from Wiseco. More throwaway bolts!!
Old Aug 25, 2022 | 06:07 PM
1FastBrick's Avatar
So they are torqued at the factory. Then torqued for mock up to measure clearances. Then torqued when you Assemble the engine....
Assuming you didn't need to torque for a mock up or anything like that because if you do then you would have to throw them away and get a new set to final assemble the engine....
I wonder what makes them different? As long as they measure properly and aren't stretched why couldn't you re use them?
Old Aug 25, 2022 | 06:09 PM
dw456post's Avatar
Dang good question
Old Nov 24, 2022 | 06:54 PM
LilJayV10's Avatar
Just because they are TTA doesn't mean they are a TTY fastener.
Old Dec 1, 2022 | 07:57 AM
dw456post's Avatar
According to Wiseco, they are good for 3 uses. Final torque 3 times. I guess that is TTA +3. If I open up the engine for rebuild, they will be replaced. I know I torqued them 3 times already.
