L8T Engine Build - NEED PISTONS
- New race prepped L8T OEM block w/unfinished 4.065 bore and 9.240 Deck Height
- Used L8T OEM Crank 3.86" Stroke
- New Boostline 6.125 Connecting Rods .927 Pin - 2.225 Big End (LS6125-927)
- Pistons Needed - 4.070 diameter, .927 Pin, 1.185 Compression Height, 12cc Dish
I know I am not the first to do this so who has the off the shelf pistons I need? Reportedly, Wiseco has made them for a few of the big engine builders, but I called every one and they do not have them on the shelf.
Anyone else planning a build like this? A few companies have made 2,000hp+ on a similar setup. Very attractive since it uses a readily available OEM block and crank. And for the record, my goal is roughly 1,000whp in a 2014 Sierra RCSB 4wd.
Thanks in advance for any thoughts or recommendations.
